Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
Re: elevated conical tank:seismic and hydrodynamic loads calculation
01-07-2014 01:25 AM in reply to: REDO10
1-Why u've chosen 3 rows of noeds? why not 4 or 5...or simply 1 ?
for simplicity, as an example
and how can I know the exact level for applying masses?
You should know how you calcaulated masses, from which range.
2- If I chosen to add masses in modal case, should I select more rows too or apply them simply in 1 row ?
See above
3-  I've enter the values such as you indicated in "masse_eau" case then convert them to masses, but when I launched calculation, this error message appears
so I've applyed them in modal case, and I obtained the results below, which seem to me wrong, especially the sum of the masses in the modal analysis and the moment along the Y axis and the shear along the X axis in combination case "G+Q+E"
File please.
Rafal Gaweda
Please use plain text.
Active Contributor
REDO10
01-07-2014 03:57 AM in reply to: Rafal.Gaweda
Hi Rafal,
See above
File please.
My file is attached to my post N°17 in page 2 (elevated_tank_1000)
Thx.
Product Support
Rafal.Gaweda
01-07-2014 07:00 AM in reply to: REDO10
My results for model from post 17
Rafal Gaweda
Active Contributor
REDO10
01-07-2014 10:15 AM in reply to: Rafal.Gaweda
Hi Rafal,
I forgot to enter the mass in the old file you calculate, so pls check this new file where I get error 5000,
question:
should I check disregrad density in modal option?
comment my results pls!
Product Support
Rafal.Gaweda
01-08-2014 05:42 AM in reply to: REDO10
Errors because of loads to mass conversion of case 17
Rafal Gaweda
Product Support
Rafal.Gaweda
01-08-2014 05:52 AM in reply to: REDO10
correct loads:
Rafal Gaweda
