Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
dummy link to transfer load
3 REPLIES 3
sibarut
1066 Views, 3 Replies
Hi, how can I make a trick to make a load that don't lie in bar but has something to hold the load in an offset distance to a moment? please see the photo to make question clearer.
Thanks.
Problems exist because there are solutions to find out.
3 REPLIES 3
Artur.Kosakowski
in reply to: sibarut
You can either create a node and connect it with another node defined along a bar with a rigid link or try to use load on eccentricity instead.
Artur Kosakowski
sibarut
in reply to: Artur.Kosakowski
Thanks. Bar force works. For rigid link, I made a node and set rigid link between 2 nodes But when I start calculate it gives me this:
Instability (of type 1) detected at node 4 in direction UX....
Is this okay? I blocked UY and RY because I don't have any force acting on these directions.
I would like to use a node to locate the force so I could easily manipulate the location because bar force eccentricity should always need some location along the bar.
Tags (1)
Artur.Kosakowski
You should block all d.o.fs.
Artur Kosakowski
