Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
display node numbers
10 REPLIES 10
Message 1 of 11
fallright
1636 Views, 10 Replies
I have 3 nodes and 1 bar.
The bar is from node 1 to 3; node 2 is in between.
When I turn on the node numbers, node number 2 isn't visible, also not the support symbol. (see attachment)
Why is this ? I work with RSA 2013.
Is this a setting ?
Tags (1)
10 REPLIES 10
Message 2 of 11
Pawel.Pulak
in reply to: fallright
Can you attach the RTD file (compressed to ZIP)?
Pawel Pulak
Technical Account Specialist
Message 3 of 11
fallright
in reply to: Pawel.Pulak
In attach the RTD-file.
I've found a "work-around" to solve my problem, but I think this can be better in a next version.
First I had 2 nodes ("1" and "2"). Then I added node "3". Then I changed in the TABLE bars "node2" in "3".
See example2.jpg.
So if you change this back in "2" and then back in "3", you will see that node "2" is'nt displayed in the view-window.
Message 4 of 11
Pawel.Pulak
This display effect is related to active "Filter Structure Stories" active for Building Design structure type.
It is enough to switch off this filtering.
See this video illustrating it: http://screencast.com/t/SkBNVXIEEEfY
The suggestion to improve this behavior registered:)
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Message 5 of 11
saclovitzky
I have the same problem, the "nodes" are not visible but their numbers are. I really do not know why I cannot see the nodes, regarding the explanation of pawel it is not really clear to me what he meant. Any comment(s) will be appreciated.
Message 6 of 11
Rafal.Gaweda
in reply to: saclovitzky
Ramon
-        Things with stories as suggested by Pawel
-        Or display for selected objects on
-        Or hide node on
-        Or Fes display off
-        Or try to turn off filling of panel interior display
Rafal Gaweda
Message 7 of 11
rioja
in reply to: Rafal.Gaweda
Ramon
the nodes are not visible because they "belong" to another story and the story is not visible, do what Pawel says and look for details for Rafals description
Message 8 of 11
gvezina
I have a similar problem that i can't resolve (see attachement)
the nodes #4 et #5 are there but it's impossible to display the node number
Message 9 of 11
rioja
in reply to: gvezina
Hi
the easiest way to display the nodes again is to renumber all, then the node number 5 will be display
I hope it helps
Message 10 of 11
gvezina
in reply to: rioja
Thank you it works !
But i don't understand why!!!!
Message 11 of 11
gvezina
If i reopen the RTD file with the "repair mode" the node number reappears..
