change moment of inertia for any section
similar to how you can change moment of inertia for a concrete beam, extend this functinality to ANY section type.
4 Comments
Tuctas
  Even better if this kind of modification can be done through the inspector dialog box (maybe just for the purposes of modelling-simulation, i.e affecting only the analysis, while for the design all the properties won't be affected).
that would be a perfect way to do it Tuctas
mgaafar
not only moment of inertia, there should be factors to all section properties (area, mass, inertia, ..)
1234eddie
See also this topic.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/corrosion-on-section/td-p/8266973
for steel sections it would be nice if you can give a offset to reduce the section dimensions.
