comment annuler ou effacer les captures effectuées!
Solved by HoshangMustafa. Go to Solution.
Hi
how to cancel or delete catptures!
I'm using ARSA 2012. Such tool is not available. In this dialog u can't delete Screen Captures.
Highlight screen capture on the list (on printout composition left panel) and press DEL key on keyboard.
Hi Rafal
I'm sorry, I tried it and it's working. When right click the screen capture, there should a shortcut menu. Now there isn't any shortcut menu.
Hi Rafal
Thanks for your reply. If there's a shortcut menu for screen captures displayed in printout composition, then one can edit it (e.g, rename, delete, bringing two or more captures into one page,..)
