hi,
i am trying to solve this cable net facade, facing an huge defficulty in analysis,
kindly support
arun
You either need to redefine boundary condition or change the model type to 2D frame (attached). In addition P-Delta is needed for all load cases.
thank you very much for your instance support. just a small query is it possible to estimate pretenion from relative elongation value. need your thoughts.
thank you once again.
Arun
@Artur.Kosakowski wrote:You either need to redefine boundary condition or change the model type to 2D frame (attached). In addition P-Delta is needed for all load cases.
Available in the stresses table.
