Hi everyone,
If I have a predefined column section in Robot with a name, for example "column 1 " with dimension 300x700 and I define the same name to column section in my Revit project 250x300
When I use Revit to Robot integration the exported section takes the dimension of the section defined in Robot not in Revit.
any solution ?
Solved by Rafal.Gaweda. Go to Solution.
This is correct. Standard sections are matched internaly by section type and dimensions, not by name.
