Bonjour,
Je n'ai pas compris l'erreur commise qui a conduit à une valeur de l'élancement très élevée?
Merci pour une explication
I'm not sure if I understand the situation. What module is it: steel design, RC Column design? Could you attach some screen capture or even better the model to look at?
c'est pas bien clair, et comment je vais imposer la valeur de la force axiale?c'est robot qui doit calculer ceci n'est ce pas?
The forces (in your case axial force plus bending moment) are taken from the verification point automatically and you do not have to make any manual changes. I changed (decreased) the value of the axial force manually only for the sake of showing the difference in verification when the critical force is and is not exceeded.
voilà alors ma question: comment je dois changer la valeur de l'effort axial que j'ai? et comment je change les coordonnées du point de vérification?
You can manually change the forces in the current verification point pressing the Forces button as shown on the picture I attached to my previous answer.
For the verification in the demand point check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Steel-design/m-p/3340849/
