Hi all
May be in the in the future may be robot could check for duplicates applied loads
1.- like self weight and display a warning or eliminate from the load table
2.- the same load applied to the same element (same load case + same load intensity), and display a warning
How about to create a load applying possibility
Linear load applied over a polyline to be defined on a slab, simulating walls over the plate.
(actually there is a possibility to do something similar)
The duplication of self weight is usually caused by copying or inserting a part of a model from one file to another. This has been resolved in SP2 for Robot 2013.
The load definition as you described it is actually possible.
