Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
What's new in Robot 2015
39 REPLIES 39
Message 1 of 40
Rafacascudo
6879 Views, 39 Replies
And do we already have a " not a guarantee"  What´s new in Robot 2015??
Rafael Medeiros
39 REPLIES 39
Message 21 of 40
Only 64-bit systems are supported.
Artur Kosakowski
Message 22 of 40
That's good news!!
Message 23 of 40
Hi.
Can i use the wind simulator like an reglementary analyse?
I ask you that because i have a big difference between an classical analys (eurocode) and the simulator.
Message 24 of 40
rioja
in reply to: Artur.Kosakowski
Kudos for the Wind Load developer team!!
Very nice update
when saving results to .csv file (e. g. reaccions) the program crash when the file is open it doesnt return "file is open" or " file is in use"
Message 25 of 40
The wind load simulation is not code based. It is a 'digital' wind tunnel.
Artur Kosakowski
Message 26 of 40
Artur.Kosakowski
in reply to: rioja
Very nice update
Thank you. I'll forward this part to them Smiley Happy
Could you give us more detailed description and an example if possible? Thank you.
Artur Kosakowski
Message 27 of 40
Any plans of including Cold formed steel member design AISI S100-2012?
Message 28 of 40
Artur.Kosakowski
I'm sorry but we will not be able to discuss any plans for the next versions of Robot on this forum.
Artur Kosakowski
Message 29 of 40
bmfrank
Might be a good idea to post this to the IdeaStation. We monitor this for future development inspiration.
Message 30 of 40
in reply to: Rafacascudo
Hello!
I can't seem to find where to check the following new feature, which is very interesting for me:
Global mode elastic instability multipliers acr calculation for building type structures
Any ideas which menu or which steps I need to follow?
Thanksss
Message 31 of 40
Have you included capacity design according to eurocodes?
Message 32 of 40
Rafal.Gaweda
Message 33 of 40
The wind load simulator looks great! Just for clarification.....is the intention for use purely as a tool for preliminary design only? Or is it intended for use to ultimatley generate design wind loads? Just curious.
Message 34 of 40
Artur.Kosakowski
I'd say both Smiley Happy
Of course it is going to be your decision - for some types of structures the wind code can give you guidance (then e.g. preliminary or  comparison analysis) but for arbitrary shapes or a structure being shielded by other buildings you may think about this kind of simulation as the good way to have some wind load estimation.
Artur Kosakowski
Message 35 of 40
Direct Analysis Method - A new approach to stability design
The Direct Analysis Method for steel frame structures is a new AISC approach for the
stability design which requires:
The addition of notional forces to the load combinations,
The reduction of the member stiffness,
P-delta local effects for the P-DELTA analysis.
Robot uses the Direct Analysis Method in conjunction with detailed option settings to
generate a supplementary model in which all the previously stated modifications are
made automatically. In addition to the standard AISC approach, it is also possible to use
customized parameters for the DAM model.
It is possible to work simultaneously with the original model and the DAM model by
selecting either model at any time. When steel member design is executed from the
original model, it uses the results from the appropriate model automatically.
The primary benefit of this approach is the possibility to check the section capacity
during the design phase, without using effective lengths or amplified moments.
A DAM analysis can be performed on any 3D model for which ULS combinations have
been defined.
http://bimandbeam.typepad.com/files/direct-analysis-method-whitepaper.pdf
Artur Kosakowski
Message 36 of 40
Pawel.Pulak
in reply to: rioja
It will be fixed in Service Pack 3 for RSAPRO 2015 - it should be available in days.
Pawel Pulak
Technical Account Specialist
Message 37 of 40
in Automatic wind load generation (CFD) option , there is a wind profile to define manually, what do you mean by those factors ? what should be included in to evaluate this speed factor ?
Message 38 of 40
Rafal.Gaweda
Message 39 of 40
What about TS500 AND TSC2007 (TURKISH SEISMIC CODE)? ARE THEY GOING TOBE TAKEN IN TO CONSIDERATION FOR THE NEXT VERSION?
Message 40 of 40
Rafal.Gaweda
in reply to: aerdemduran
Register wishes here:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/idb-p/93
Rafal Gaweda
