I'd like to know if there is a way to calculate the self weight of a group of profiles, for example the weight of all columns of a structure or the weight of all the beams positioned at a certain level.
Thank you
Giorgio
Solved by RobertoPalladino. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
1. Create a new load case
2. Define self-weight load on the selected part of the model only
3. Calculate model
4. Check total sum of vertical reactions
Hi Giorgio,
probably you only need a list of weights of profiles, in this case you can use the table of quantities
Bye
Roberto Palladino
