Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Water pressure Value !
2 REPLIES 2
Mohammed_Ata
524 Views, 2 Replies
When i define water pressure of unit weight = 1000kg/m3 and height=8m
load values sre showed as phyd = (0.0 , 1.0)
2 REPLIES 2
dimogrec
in reply to: Mohammed_Ata
0 is  the costant (part) pressure along height (as it is defined by you in the pressure table)
1.0 is the varying linearly pressure (always as defined by you in the pressure table) I imagine you're working with tons (units) so 1000Kg/m3=1ton
Some other things.. Make sure to assign the right height and change panel Z direction to have the right direction of your pressure. You can do this form "Geometry->Proeperties->Local panel direction"
Check also these
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Silo-hydrostatic-pressure/m-p/4912320#M22097
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Hydrostatic-Pressure/m-p/3476666#M5141
Mohammed_Ata
i know that panel's direction is to be modified , i want to know what values mean .
thank you so much , dimogrec 🙂
mohammed
