Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Warping Constant using AISC member
8 REPLIES 8
Message 1 of 9
CameronEC
5514 Views, 8 Replies
AISC members have a warping constant (Iom or Cw) = 0 using the member from the AISC database. (see below).
But when I use this member with the CSA S16-09 design code, I get results that assign a value to Cw (see below)
Where is ROBOT getting the value of Cw?
8 REPLIES 8
Message 2 of 9
It is calculated 'inside' the steel design module either based on formulas form the selected design code or the general ones for the declared section type. E.g.
Artur Kosakowski
Message 3 of 9
in reply to: Artur.Kosakowski
Artur,
This answer is also useful for my last post on Lateral Bucklyng of Tapered Section.
Smiley Happy
Message 4 of 9
Hello!
Is there an calculation formula how to calculate Iw for rectalngular cross section? I find for all cross sections except rectangular.
Tags (1)
Message 5 of 9
Artur.Kosakowski
  alpha=b-t
  beta=h-t
  Iw=alpha*alpha*beta*beta*(alpha-beta)*(alpha-beta)*t/(24.0*(alpha+beta))
Artur Kosakowski
Message 6 of 9
Artur.Kosakowski, Would you please provide the reference of that table? Thanks.
Message 7 of 9
Artur.Kosakowski
Hi @Anonymous
It is from the Polish steel design code.
Artur Kosakowski
Message 8 of 9
Thank you, @Artur.Kosakowski !
Message 9 of 9
I was trying to get a consistent method to calculate the warping constant (Cw) of closed sections and I wanted to compare it with an analytic formula. Could you tell me what is the source of the one you published here? It's easy to find warping constant formulas for open sections, not so much for closed ones. Thanks in advance.
