Discussion Groups
Robot Structural Analysis
pta_simon
Walls are tilting after meshing
158 Views, 5 Replies
02-24-2014 04:01 AM
I am having a problem with the walls around a lift core of an RC building I am modelling.
I have built the core walls up and checked that they line up correctly and have then proceeded to mesh my building. The problem I have encountered is that the walls around my lift core are then being tilted after this process. It seems as if Robot is altering the geometry of the core walls. Please see attachment for screenshots of my problem.
Why is the geometry being affected and causing the walls to tilt after I mesh the structure?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Walls are tilting after meshing
02-24-2014 04:05 AM in reply to: pta_simon
Could you attach the model please?
Artur Kosakowski
pta_simon
02-24-2014 04:13 AM in reply to: Artur.Kosakowski
Product Support
Artur.Kosakowski
02-24-2014 05:51 AM in reply to: pta_simon
I think that the situation is just the opposite. The geometry of the panels is inaccurate but the meshes try to adopt to the neighbouring ones so that the mesh is coherent.
Artur Kosakowski
pta_simon
02-24-2014 06:36 AM in reply to: Artur.Kosakowski
Is there a way of stopping the meshing programme from moving panels to 'fix' itself? I would rather the programme highlighted areas where there is a problem rather than adjusting co-ordinates which, based on this model, is creating problems but hiding them.
Screenprint of the meshing options is attached for reference.
Product Support
Artur.Kosakowski
02-24-2014 07:02 AM in reply to: pta_simon
Meshing do not change definitions of panels' geometry. The verification run after model generation indicates where you have the problems with meshing. The range of mesh adjustment to inaccurate geometry is governed by the tolerance of the model generation.
I would suggest that when you know that you have a model that has been incorrectly defined you first correct the geometry of the model either by the detailed correct option or by one of the macros available from the forum and then you mesh it. For the locations you have still issues you then focus on one by one e.g. manually correcting either panels or just position of generated nodes of the meshes.
Artur Kosakowski
