Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Wall support around void on Revit and Robot
8 REPLIES 8
Message 1 of 9
elliotsmith
299 Views, 8 Replies
Can you please advise why the walls under are not supporting the slab edge at a lift void. It won't provide a connection
I have ensured the analytical wall lines up perfectly with the slab edge but it doesn't seem to make a difference.
This has happened on a another project using Revit/Robot 2014 and I had to join all the slabs to edge of void walls manually.
Elliot
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: elliotsmith
Revit file please.
Rafal Gaweda
Message 3 of 9
elliotsmith
in reply to: Rafal.Gaweda
The file is 10mb, can you please suggest a way of compressing it?
Message 4 of 9
Rafal.Gaweda
Message 5 of 9
elliotsmith
Message 6 of 9
Rafal.Gaweda
PLeas explain on model you sent us
I do not see any problem :slabrevit.jpg red object  = slab
Rafal Gaweda
Message 7 of 9
Rafal.Gaweda
BTW : there are no slab openings on some slabs
Rafal Gaweda
Message 8 of 9
Looks like this is in the extensions for Revit tool inside of Revit.  If it is not working, I assume you will need to check to see that the analytical models of the slab opening align wtih the walls which support it.  You may need to adjust the walls with the analytical wall adjustment tool to achieve this.  What is the error message that the slab analysis tool give you?
Message 9 of 9
I just looked at the model and it seems reasonably well connected. This is a bit of a shot in the dark, but have you tried ungrouping them? Structural elements don't necessarily like groups all the time. I'll have to download the extensions to have a better look at this issue.
