Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Wall it and load wall
6 REPLIES 6
563 Views, 6 Replies
Hi all.
Please check 2 modol same, But results other, Why ???/
I is send modol below
6 REPLIES 6
Romanich
You must use "dummy" bar under bearing wall.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
in reply to: Romanich
You can edit the model to help me.
I is attchment model.
Artur.Kosakowski
1. You should change linear load to have the same reactions
2. Bending of  a T shape is not the same as bending a flat bar.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thanks you.
If i use nonbearing wall . I should give it a wall or panels or shell or clading??????
Romanich
example with nonbearing wall attached.
Roman Zhelezniak
Thansk you.
But i don't kwon. Why Pz= 7,65 kN/m ?????/?
