Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
WEIRD MOMENT ON SECONDARY BEAMS
5 REPLIES 5
401 Views, 5 Replies
HEY,
i am design the secondary and primary beams supporting the deck slab
Panel 28 is in the X direction while i want panel 31 in y direction
But im getting negative moments on the secondary beams in pnael 31 which is definitely wrong,
can someone help me to find out my mistake.
http://www.filemail.com/d/lfmkbmydcbdffwh
George
5 REPLIES 5
Rafal.Gaweda
If I understood you correclty:
Rafal Gaweda
in reply to: Rafal.Gaweda
hey Rafal,
just to make things clear since i am a bit confused.
So if i want a deck slab to be in  the y direction there is an option in deck slab properties to use y direction is this as if i have put x direction then changed the panel direction as u have mentioned above?
Rafal.Gaweda
Rafal Gaweda
Whenever i am doing this i am getting negative moment  My  for secondary beams which is wrong bar(20,30,32 etc)...
http://www.filemail.com/d/dfryzyhrgknxdgv
Rafal.Gaweda
Eevrything is correct.
Check displacement first
Rafal Gaweda
