HEY,
i am design the secondary and primary beams supporting the deck slab
Panel 28 is in the X direction while i want panel 31 in y direction
But im getting negative moments on the secondary beams in pnael 31 which is definitely wrong,
can someone help me to find out my mistake.
http://www.filemail.com/d/lfmkbmydcbdffwh
George
hey Rafal,
just to make things clear since i am a bit confused.
So if i want a deck slab to be in the y direction there is an option in deck slab properties to use y direction is this as if i have put x direction then changed the panel direction as u have mentioned above?
Whenever i am doing this i am getting negative moment My for secondary beams which is wrong bar(20,30,32 etc)...
