My ViewCube is missing... Even if it indicates it is on, its not visible. But when i put the cursor in the upper right hand corner, my cursor indicates that the ViewCube is there but not visible. My settings are in default and im Robot Pro 2011.
Thank you.
Solved by Artur.Kosakowski. Go to Solution.
Try to reduce the display acceleration as shown on the attached picture please.
