how we can speed up copy/move elemenets in Robot model? I need to copy set of panels and lines from column to column and it's very very slow. Maybe I didn't know some trick
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Artur.Kosakowski. Go to Solution.
Artur, nothing happens...
Roman Zhelezniak
Try to switch off display of interiors and thicknesses on ALL VIEWERS (mind that for the building model the viewer has got TWO tabs) including the additional ones you opened.
Artur, this didn't help me. Also I'm tried to switch off selection synchronization between views, but this didn't help too.
Roman Zhelezniak
Please make sure you switched off display of these attributes on ALL viewers. I have tested this on my computer before posting the answer to check it works. Please send me the screen capture that shows how your screen (in Robot) looks like just before trying to run copying.
This is a screen:
On a Plan view settings the same.
Please, try to copy elements 8309to8336 for example.
Also, when I'm working in English language version of Robot, after each save Robot show this dialog:
Roman Zhelezniak
See the movie
http://screencast.com/t/5sXngzMdzO
Before opening the Display dialog I pressed the default display button to make sure that I have the control over the settings you made in the file.
Thank you, Artur! Last trick has decided my issue.
Roman Zhelezniak
