Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Vault calculation with robot
7 REPLIES 7
Message 1 of 8
kannel
471 Views, 7 Replies
Hey,
Maybe someone can give me some advice. I have to find out internal forces of a vault in FEM caused by only its own weight. The existing vault has been 3D scanned and the pointcloud has already been processed. Now I have joined the points into a mesh and imported the dxf file to ARSA. In that point I have no idea what to do next. I have tried different ways but dont get the result. Should I turn the mesh to a solid or use panels or smthig else...
Appreciate if someone could help!
This is what I have now:
7 REPLIES 7
Message 2 of 8
t.sautierr
in reply to: kannel
Attach File please.
Message 3 of 8
Artur.Kosakowski
in reply to: kannel
For dxf import check the message 3 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autocad-dwg-files-import/m-p/3181550
Artur Kosakowski
Message 4 of 8
kannel
in reply to: t.sautierr
Message 5 of 8
Artur.Kosakowski
in reply to: kannel
Assign the correct thickness and support the structure.
Artur Kosakowski
Message 6 of 8
kannel
in reply to: Artur.Kosakowski
Thank you very much!
Can you tell me what you did there?
Message 7 of 8
Artur.Kosakowski
in reply to: kannel
Message 8 of 8
kannel
Got it!
That was very useful. Thanks for your time!
