Hey,
Maybe someone can give me some advice. I have to find out internal forces of a vault in FEM caused by only its own weight. The existing vault has been 3D scanned and the pointcloud has already been processed. Now I have joined the points into a mesh and imported the dxf file to ARSA. In that point I have no idea what to do next. I have tried different ways but dont get the result. Should I turn the mesh to a solid or use panels or smthig else...
Appreciate if someone could help!
This is what I have now:
Solved by Artur.Kosakowski. Go to Solution.
For dxf import check the message 3 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autocad-dwg-files-import/m-p/3181550
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Assign the correct thickness and support the structure.
