Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
VBA cases and combinations
8 REPLIES 8
Message 1 of 9
mateaus
831 Views, 8 Replies
Hi
I already create cases in my model and I would like to add cases with VBA to this one.
3 : equipements
I only know this command but it create new cases.
Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _
casdecharge, typecharge, I_CAT_STATIC_LINEAR)
Can you give the command to select cases in order to define new loads ?
I'd like also to create combinations like ?
type : linear
nature of case ELS
name COMB1
number 101
0.5 * 1 + 1 * 2 + 6 * 3
How can I make it ?
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: mateaus
Code for creating combination
Dim Loads As RobotCaseServer
Set Loads = RobApp.Project.Structure.Cases
Dim cmb As RobotCaseCombination
Set cmb = Loads.CreateCombination(110, "COMB1", I_CBT_ALS, I_CN_EXPLOATATION, I_CAT_COMB)
cmb.CaseFactors.New 1, 0.3
cmb.CaseFactors.New 2, 1
cmb.CaseFactors.New 6, 1
Rafal Gaweda
Message 3 of 9
Rafal.Gaweda
in reply to: Rafal.Gaweda
Seleting case for eg adding loads:
 Dim RCase As RobotSimpleCas
Set RCase = Loads.Get(3)      '/ where 3 is real case number
then create and set records for RCase
Rafal Gaweda
Message 4 of 9
bensalahsayf.edd
Hi Rafal Gaweda,
How to use this combination with vba and much thank  
Message 5 of 9
Hi Rafal Gaweda
How to use this combination with VBA and much thank ...Capture.PNGnd much thank
Tags (1)
Message 6 of 9
Message 7 of 9
Much Thank Rafal Gaweda
' G2 = CASE 2 + CASE 3
' Q1 = CASE 4 + CASE 5
' Q2 = CASE 6 + .... + CASE 14
Tags (1)
Message 8 of 9
bensalahsayf.edd
How to create relation with group in VBA and thank
Message 9 of 9
Hi Rafal Gaweda,
Plz how to use the relation between 2 groups with code VBA and much thank
Example :
G1 And G2
Q1 Or Q2
