Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
VBA and compatible nodes
1 REPLY 1
hbernardo
252 Views, 1 Reply
I´m having some trouble on VBA creating compatible nodes on VBA. I can create the label and create compatible nodes being part of bars, but the issue arises when I try to make compatible two nodes of two shells (plates), i.e. something that is not a bar.
How can I select the nodes and asign the compatible node label?
Can anybody please post some code as an example?
Thanks in advance.
1 REPLY 1
Rafal.Gaweda
in reply to: hbernardo
Not possible to make "trick" to create compatibility between panels nodes by API.
Rafal Gaweda
