Discussion Groups
Robot Structural Analysis
Active Contributor
jamalsid
Re: VBA Excel macro for any object geometry modifications
09-28-2012 06:20 AM in reply to: Rafal.Gaweda
How do I do actually run the below command? Do i need to open a cmd prompt first, then rund the relevant commands? Do I run them with or without the quotations?
RG_Adsk wrote:
In such case unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
Please use plain text.
Product Support
09-28-2012 06:31 AM in reply to: jamalsid
Valued Contributor
Leader_Mohamed
01-18-2014 06:22 AM in reply to: Rafal.Gaweda
Thx for this macro but I can import only panel contors and if I select some bars to change the coardiantes , a meesage appera that I'm not sellecting any thing
Product Support
01-20-2014 12:55 AM in reply to: Leader_Mohamed
Bars do not have any coordinates so it is impossible to correct them.
You can correct nodes coordinates in Nodes table or using this addin : http://forums.autodesk.com/t5/Robot-Structural-Analysis/Rounding-up-coordinates-API/td-p/3430533/pag...
Rafal Gaweda
01-30-2014 06:56 AM in reply to: Rafal.Gaweda
With this addin we can only round up or down nodes coordinates, how can we modify them?
Thank you!
Product Support
01-30-2014 11:38 PM in reply to: ClémentTAHERI6316
Robot -> Nodes table
Rafal Gaweda
01-31-2014 12:23 AM in reply to: Rafal.Gaweda
Thank you.
Thanks to you I have an addin for modifying panels. Is there any addin for nodes?or how to write it in API?
Saraneiya
Product Support
01-31-2014 01:24 AM in reply to: ClémentTAHERI6316
Example attached.
Rafal Gaweda
