Discussion Groups
Robot Structural Analysis
Product Support
VBA Excel macro for any object geometry modifications (API)
3051 Views, 17 Replies
10-12-2011 05:31 AM
Hi
For those who might be interested I am attaching xls file with macro for objects geometry modifications.
One button to import geometry (characteriscic points coordinates) of selected objects (lines, polylines, arc, circles, panels), second - to update their geometry basing on data in Excell.
NOTE: modify only cells with coordinates.
Rafal Gaweda
Please use plain text.
Member
Perhed
Re: VBA Excel macro for any object geometry modifications
10-12-2011 08:26 AM in reply to: Rafal.Gaweda
Hello!
I tried your excel sheet, but it doesn´t recoginze that robot is open.
How should i use the macro?
/Per
Product Support
10-13-2011 12:06 AM in reply to: Perhed
Hi
Go to VBA Editor (Alt+F11), go to References, unmark Robot Object Modeler, close References window by pressing OK, open it again, select  Robot Object Modeler ver. 12.0., press OK
Rafal Gaweda
Member
Perhed
10-14-2011 12:05 AM in reply to: Rafal.Gaweda
I´ve tried your solution on the problem, but it still gives the same error message.
/Per
Product Support
10-14-2011 12:49 AM in reply to: Perhed
Try:
1. Run Excel as Administrator, run Robot as Administrator, then check macro
2. Check \ set UAC :
Rafal Gaweda
Member
Perhed
10-14-2011 01:18 AM in reply to: Rafal.Gaweda
This gives the same error.
Product Support
10-14-2011 01:30 AM in reply to: Perhed
I need to ckeck it on your computer
Please register this isseu as Service Request or give me your details in Private Message
Rafal Gaweda
Product Support
10-14-2011 04:15 AM in reply to: Rafal.Gaweda
In such case unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
Rafal Gaweda
Active Contributor
RoboExploiter
02-12-2012 05:52 PM in reply to: Rafal.Gaweda
I had the same problem which i managed to solve with the help of the structural support team:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-API-for-ARSA-2012-error-429/td-p/32153...
A colleague of mine recently upgraded from ARSA 2011 to 2012, and our excel VBA API was unable to recognise that 2012 was open.  I tried to deregister both and register 2012 (with administration rights) with the method described in this post, but it didn't work.
I remember last time this happened Structural Support and I worked through the registry looking for and deleting outdated ARSA 2011 entries... can you tell me what to look for, what to delete, and what to keep?
Product Support
09-28-2012 12:46 AM in reply to: RoboExploiter
JUst to link some threads .
Modified macro with rounding:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Panel-contour-points-modification-API/td-p/3...
Rafal Gaweda
