Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
VBA Excel macro for any object geometry modifications (API)
3279 Views, 17 Replies
10-12-2011 05:31 AM
Hi
For those who might be interested I am attaching xls file with macro for objects geometry modifications.
One button to import geometry (characteriscic points coordinates) of selected objects (lines, polylines, arc, circles, panels), second - to update their geometry basing on data in Excell.
NOTE: modify only cells with coordinates.
Rafal Gaweda
Please use plain text.
Member
Perhed
Re: VBA Excel macro for any object geometry modifications
10-12-2011 08:26 AM in reply to: Rafal.Gaweda
Hello!
I tried your excel sheet, but it doesn´t recoginze that robot is open.
How should i use the macro?
/Per
Product Support
Rafal.Gaweda
10-13-2011 12:06 AM in reply to: Perhed
Hi
Go to VBA Editor (Alt+F11), go to References, unmark Robot Object Modeler, close References window by pressing OK, open it again, select  Robot Object Modeler ver. 12.0., press OK
Rafal Gaweda
Member
Perhed
10-14-2011 12:05 AM in reply to: Rafal.Gaweda
I´ve tried your solution on the problem, but it still gives the same error message.
/Per
Product Support
Rafal.Gaweda
10-14-2011 12:49 AM in reply to: Perhed
Try:
1. Run Excel as Administrator, run Robot as Administrator, then check macro
2. Check \ set UAC :
Rafal Gaweda
Member
Perhed
10-14-2011 01:18 AM in reply to: Rafal.Gaweda
This gives the same error.
Product Support
Rafal.Gaweda
10-14-2011 01:30 AM in reply to: Perhed
I need to ckeck it on your computer
Please register this isseu as Service Request or give me your details in Private Message
Rafal Gaweda
Product Support
Rafal.Gaweda
10-14-2011 04:15 AM in reply to: Rafal.Gaweda
In such case unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
Rafal Gaweda
Active Contributor
RoboExploiter
02-12-2012 05:52 PM in reply to: Rafal.Gaweda
I had the same problem which i managed to solve with the help of the structural support team:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-API-for-ARSA-2012-error-429/td-p/32153...
A colleague of mine recently upgraded from ARSA 2011 to 2012, and our excel VBA API was unable to recognise that 2012 was open.  I tried to deregister both and register 2012 (with administration rights) with the method described in this post, but it didn't work.
I remember last time this happened Structural Support and I worked through the registry looking for and deleting outdated ARSA 2011 entries... can you tell me what to look for, what to delete, and what to keep?
Product Support
Rafal.Gaweda
09-28-2012 12:46 AM in reply to: RoboExploiter
JUst to link some threads .
Modified macro with rounding:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Panel-contour-points-modification-API/td-p/3...
Rafal Gaweda
