Where is the user defined shape directory? Also, after I define a custom shape, how can I save it so that I can edit it again. Robot won't let me edit the .sec file I saved the custom shapes to.
Solved by Artur.Kosakowski. Go to Solution.
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
Win 7 32- or 64-bit RSAPro:
You can edit the section in the Section Builder module after opening it from the selected database:
To open *.sec file use:
