How are you all .. i want our help .. i tried to find this curve by using moving load but i can't .. can someone help me how i can do it ..
the link is here http://rebar.ecn.purdue.edu/lrfd2/Hammerhead/3cdle/3cdle2.aspx
Thanks a lot
Hi
Please check this link
http://www.robotoffice.com/rsa/
Find: Using moving loads
http://www.robotoffice.com/rsa/hrh_flm/044_films_robot.htm#
i know how i can moving load .. but my problem is how is apply moving load on pier and find this curve ... just i want to know the area of influence .. i hope if i explain clear
just i want to see how the steps he's doing to find this curve ..
okay .. i know i ask too much .. you told me that's easy just give me a favour and show me by viedo on this case .. you should be focus the loads on pier as in this example is concentrated loads and that's from strut and tie models
