Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Unidirectional release
5 REPLIES 5
818 Views, 5 Replies
what I'd like to know is:
does "Released direction" mean that there is no restraint in that direction?
For example, does released direction Ux+ mean "no restraint in Ux+"?
In the attached sketch you can see my doubt.
Thank you.
5 REPLIES 5
Rafal.Gaweda
Take a look at this help topic:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-A65C66FB-20DA-4B7C-BFE2-3A7B0CF54F7-249.htm
UX+\- shows different direction depending on bar start \ end
Rafal Gaweda
Oh, yes! ... But I think that it is exactly the opposite!
Rafal.Gaweda
Take a look below, no compression (yellow diagram , Fx force) on right hand side beam due to release Ux+ defined at the beginning of this bar, tension in left bar
Rafal Gaweda
in reply to: Rafal.Gaweda
I think the problem is solved:
let's take a look to the central node; the situation should be
this means that the 1st node of the 2nd bar is free in Ux+, while the whole bar is free in Ux-.
Due to the fact that there is a DSC element (is it correct?), the node and the bar move in opposite directions.
So the "beginning node of the bar element" (User's guide) is the node 1 of my sketch, while I intended that it was the "new node" of my sketch (they can move in opposite directions).
Giorgio
Rafal.Gaweda
DSC algorithm creates connections between phisical node (on your screen capture node 1, on mine (below) node 2) and calculation node (on your screen capture "new node", on mine  - node 10).
In our situation (unidirectional realease UX+) such link does not exist between these two nodes only in UX+ direction so node 1 (or 2 on my example) can be displaced but your "new node" (mine node 10) remains in the same position.
In case of opposite direction force these nodes will act toghether:
Rafal Gaweda
