HI
I have calculated my model which supposed to be equally loaded, but as the attached picture shows it is uneven. I have used rigid links so the load should be evenly distributed. But it clearly shows that its something wrong here. Can you give me some advice to fix this.
Solved by Rafal.Gaweda. Go to Solution.
Czeck LCS of panels. I guess some of them has opposite direction.
If it is not the case please send us model.
