Hello, I have two problems:
-as I can orient the reference system more panels in the same direction automatically?
-in a model I find this problem, but I can not figure out where the model is wrong?
(i attach the file)
thanks
Solved by Rafal.Gaweda. Go to Solution.
answer for your first question is Yes.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
I will check the model but take a look at this thread http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-Nr-100/m-p/3602456/highlight/true#M713...
It is caused by not connected rigid link and some nodes not connected to bars located on claddings egdes \ corners.
Corrected file attached.
