Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
HoshangMustafa
271 Views, 5 Replies
Two column footing
Hi
What should I do to export two column loads to design a spread footing carring two column loads?
how the loads of two columns are exported to the design module?
5 REPLIES 5
The procedure is exactly the same as for a single column spread footing. Just select both columns and answer yes for the question about the design of the foundation for two columns.
Artur Kosakowski
Hi Artur
Thank you.
If I choose two columns, then the program will design columns instead of foundation. If I select nodes then the program will design single column footing. Please step by step or video.
Please check http://forums.autodesk.com/t5/Robot-Structural-Analysis/combined-footing/td-p/4889394
Artur Kosakowski
Hi
Can you provide a screen cast? I read the las post and I couldn't catch anything
Here you are
Artur Kosakowski
