Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Truss insertion error
10 REPLIES 10
Message 1 of 11
dan.suciu
1236 Views, 10 Replies
I am trying to insert a truss element from the library, but as soon as I finish editing the parameters,
and click apply,ok  , it gives me an error(this is valid for all library elements)
I have tried going in different project types to see if this is the problem , but same error appears.
i have attached the error mesage,\
the error is :
Syntax incorect:line ignored
(2*%NF-1) %DIAGS "gamma" %DIAGSgamma
thanks in advance,
Dan,Suciu
10 REPLIES 10
Message 2 of 11
What language do you work with in Robot and what are the material and steel section databases declared in Job Preferences?
Artur Kosakowski
Message 3 of 11
the regional settings and printout language is Romanian, the working language is English
the material database is Eurocode with S460M M/L
the steel section database is ROMAN (for romanian steel products)
Message 4 of 11
The library structures are based on the text files which are language dependent. For Romanian regional settings they have French name for steel (Acier) material assigned which doesn't exist in the Eurocode material database. Please add it  in the way shown on the attached picture. Of course you should change the material of bars to the intended one after inserting the truss.
Artur Kosakowski
Message 5 of 11
thank you,
this has solved the problem
Message 6 of 11
ROBOT97 Triangular Truss Type 1
TRU PLA
VER NON
VAR
SECTION "Dimensions" "d_tria1"
  %UP = [BOOL] ?"0" : *First Diagonal Up
  %SLL=]0.0,100000.0,ULENGTH] ?"30.0" : *Length L:
  %SH=]0.0,100000.0,ULENGTH] ?"6.0"   : *Height H:
  %NF=[4,50] ?"6" : *Number of Fields:
  %MEMB=[BOOL] ?"1" : *Continuous chord
  %REL=[BOOL] ?"1" : *Moments Released
SECTION "More..." "d_tria1a"
  %DIS=[0.0,1000.0,ULENGTH] ?"0.0"    :*Distance 😧
  %DID=[0.0,1000.0,ULENGTH] ?"0.0"    :*Distance D1:
SECTION "Sections" "d_tria1"
  %CHORU= [profil]?"WT 12x52"               : *Upper Chord -
  %CHORUgamma= ?"0"                         : * - gamma angle =
  %CHORL= [profil]?"WT 12x42"               : *Lower Chord -
  %CHORLgamma= ?"180"                       : * - gamma angle =
  %DIAGS= [profil]?"DL 2x2x0.25"            : *Diagonals -
  %DIAGSgamma= ?"0"                         : * - gamma angle =
  %POSTS= [profil]?"DL 2.5x2.5x0.25"        : *Posts -
  %POSTSgamma= ?"0"                         : * - gamma angle =
VAR END
NUM DIS
UNITS
Len=ft Force=kip
NOD
1 0 0
#if %DIS = 0.0
1 tra x=(%SLL/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF)  (%SLL/2) (%SH)
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH-2*%SH/%NF) (%SLL-%SLL/%NF) (2*%SH/%NF)
#else
1 tra x=(%SLL/%NF) z=(%DIS/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF+(%DIS/%NF))  (%SLL/2) (%SH+(%DIS/2))
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH+(%DIS/2)-2*%SH/%NF+(%DIS/%NF)) (%SLL-%SLL/%NF) (2*%SH/%NF+%DIS-(%DIS/%NF))
#endif
#if %DID > 0.0
1 tra x=(%SLL/%NF) z=(%DIS/%NF+(2*%DID/%NF)) 2 G (%NF/2)
(%NF/2+1) tra x=(%SLL/%NF) z=(%DIS/%NF-(2*%DID/%NF)) (%NF/2+2) G (%NF/2)
#endif
ELE
#if %MEMB = 0
1r(%NF-1) 1 2
(%NF+1) 1 (%NF+2)
(%NF+2)r(%NF-3) (%NF+2) (%NF+3)
(2*%NF) (2*%NF) (%NF+1)
#if %UP = 1
 (2*%NF+1)r(%NF/2-2) 2 (%NF+3)
 (2*%NF+%NF/2)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
#else
 (2*%NF+1)r(%NF/2-2) 3 (%NF+2)
 (2*%NF+%NF/2)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
#endif
(3*%NF+1)r(%NF-2) 2 (%NF+2)
#else
    #if %DID=0
     1 1 (%NF+1)
     2 1 (3*%NF/2+1)
     3 (%NF+1) (3*%NF/2+1)
    #else
     1 1 (%NF/2+1)
     2 (%NF/2+1) (%NF+1)
     3 1 (3*%NF/2+1)
     4 (%NF+1) (3*%NF/2+1)
    #endif
     #if %UP = 1
      100r(%NF/2-2) 2 (%NF+3)
      (100+%NF/2-1)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
     #else
      100r(%NF/2-2) 3 (%NF+2)
      (100+%NF/2-1)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
     #endif
     200r(%NF-2) 2 (%NF+2)
#endif
PRO
STEEL
#if %MEMB = 0
 1to(%NF)                  %CHORL "gamma" %CHORLgamma
 (%NF+1)                   %CHORU "gamma" %CHORUgamma
 (%NF+2)to(2*%NF-1)        %CHORU "gamma" %CHORUgamma
 (2*%NF)                   %CHORU "gamma" %CHORUgamma
 (2*%NF+1)to(5*%NF/2-1)    %DIAGS "gamma" %DIAGSgamma
 (2*%NF+%NF/2)to(3*%NF-2)  %DIAGS "gamma" %DIAGSgamma
 (3*%NF+1)to(4*%NF-1)      %POSTS "gamma" %POSTSgamma
#else
    #if %DID=0
     1 %CHORL "gamma" %CHORLgamma
     2 3 %CHORU "gamma" %CHORUgamma
    #else
     1 2 %CHORL "gamma" %CHORLgamma
     3 4 %CHORU "gamma" %CHORUgamma
    #endif
     #if %UP = 1
      100to(100+%NF-3) %DIAGS "gamma" %DIAGSgamma
     #else
     #endif
     200to(200+%NF-2) %POSTS "gamma" %POSTSgamma
#endif
  REL
#if %REL = 1
#if %MEMB = 0
   ELE 1to(%NF)                  ORI ry  END ry
   ELE (%NF+1)                   ORI ry  END ry
   ELE (%NF+2)to(2*%NF-1)        ORI ry  END ry
   ELE (2*%NF)                   ORI ry  END ry
   ELE (2*%NF+1)to(5*%NF/2-1)    ORI ry  END ry
   ELE (2*%NF+%NF/2)to(3*%NF-2)  ORI ry  END ry
   ELE (3*%NF+1)to(4*%NF-1)      ORI ry  END ry
#else
    #if %DID=0
     ELE 1 ORI ry  END ry
     ELE 2 3 ORI ry  END ry
    #else
     ELE 1 2 ORI ry  END ry
     ELE 3 4 ORI ry  END ry
    #endif
     #if %UP = 1
      ELE 100to(100+%NF-3) ORI ry  END ry
     #else
     #endif
     ELE 200to(200+%NF-2) ORI ry  END ry
#endif
#endif
  SUP
END
SUP
1 (%NF+1)
LOA
CASE # 1
(%NF+2)to(2*%NF) Fz=-1.0
END
Message 7 of 11
edyez
in reply to: dan.suciu
salut aceeasi problema am si eu .....zi mi exact te rog **** ai facut ...am incercat sa aplic ce am vazut in imaginea aceea atasata si tot nu a mers ! ms fain
Message 8 of 11
edyez
in reply to: Artur.Kosakowski
i have done what you say , and it doesn`t work ... pls give me details ... greetings !
Message 9 of 11
Artur.Kosakowski
in reply to: edyez
Could you give me the answers on the questions from the message 2?
Artur Kosakowski
Message 10 of 11
edyez
I set all over the Romanian language ! and the second problem : i can` t set up ASD in Preferences (there is ASD and ROBOT - with robot checked). thanks
Message 11 of 11
Artur.Kosakowski
in reply to: edyez
Add Acier to the list of materials
I don't understand this point. Could you make some screen capture that illustrates it?
Artur Kosakowski
