Hey,
I am having some problems in my truss axial forces results,
The tension member forces is way different than the compression member forces.
Please can you check my model if i have done any mistake
I would appreciate if you can help me
http://www.filemail.com/d/fcnhzigqsdmjzbs
For example bar 258 and 385 ( which are the top and bottom chord of the truss)
for Case U12 the axial force Fx on the top chord ( 258) is very small comparing to the bottom chord (385)
Top chord is located in concrete slab. Slab transfers almost all forces. Delete bar 258 and you will see only small change in bottom chord forces case 1 : -1225 vs -1175 on bar 385
what i have tried to do is deleting the slab; so i have gotten the balance in my truss the top chord and bottom chord forces values are very close now
But an unstability has occured 😞 can you help me again in this
http://www.filemail.com/d/ghvmqdyusjloood
