Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Trouble modeling suspension bridge with rigid links
1 REPLY 1
AdamBarnett
1079 Views, 1 Reply
I've been working on modeling a suspension for a class project and I have been encountering instability issues when I add rigid links to connect the deck beams to the cables. I was adding the links in so the bridge beams would cover half the deck and still connect to the cables. When I have modeled a suspension bridge without rigid links it has worked fine so my settings for a non linear analysis and cable definition should be correct.
I have tried every setting on the rigid link that I can think of. I have attached the model I have been working on, could someone please take a look and help me with the necessary settings or offer advice on an easier way to model the bridge.
Thanks in advance
1 REPLY 1
Rafal.Gaweda
in reply to: AdamBarnett
Nonlinear pdelt acalculations should be carried on.
Then you have to play with cables assembling parameters to obtain convergence.
Rafal Gaweda
