Hi all,
Does the software make good calculations for this two bucklings with user sections?
In case YES, does it depend on the kind of section? Both thin and solid?
I'm reviewing some calculations but doesn´t match with the ones I've done manually. In fact, in the robot detailed results I can not find all the parameters needed to get the Ncr,T (EN313 (6.2.3) such as the warping constant Iw and the io, so I don't really know which parameters Robot is taking into account.
Appendix C
and the io
Formula (6.33b)
Yes....
but, where can I check the the final value Iw and io robots takes into account??
These are crtical values in the formulas, should be appear in the detailed report.
Iw is available.
I don't have that parameter in my detailed report.
I get this messsage when run member verificacion calculations:
For bars 6269 the program has not performed the lateral buckling verification. Bars were assigned such section types for which the program does not perform the lateral buckling analysis or the lateral buckling verification is not required (for example My = 0.0 - no bending).
It is an user section.
What was the way you created this section?
Have you read http://forums.autodesk.com/t5/Autodesk-Robot-Structural/How-to-create-thin-walled-sections/td-p/3107... ?
I created it drawing the shape directly in the section definition window as a thin walled section.
My shape is not similar to any of the ones already created in the cataloges.
Then you have not been able to assign the 'correct' (thin walled) section type to it which influences the verification process. I would recommend that you follow the description I provided in the 'thin walled' topic on the forum and replace the properties of the best matched section form one if the section databases with the ones you calculated for the one you created.
Our company's product range is over 100 sections (ten geometries x ten thicknes, at least..).
I can not do this as a global solution, I can not do this to include in a technical report for endorse a project.
Hope Robot developers are working hard with this issue that is requierd for lots of users.
Regards.
Am I correct to assume that you mean code checking of thin walled profiles of arbitrary shapes?
