Can Robot model a timber shearwall lateral force resisting system? If so, How do you specify the nailing?
Thanks in Advance
Solved by Artur.Kosakowski. Go to Solution.
Thanks for the quick reply. Is there an autodesk product to analyze timber shearwalls?
Spreadsheet Calculator. Available in French and according to European codes.
