431 Views, 3 Replies
Timber Beam
Hi, I'm new with autodesk Robot, so i want to ask in my opionion very simple question 🙂 but i'm struggling at finding how to do two-slope beam.
I need timber beam with 0,88m in sides and 1,68 in middle.
3 REPLIES 3
Artur.Kosakowski
Try to use the tapered timber section applied to two bars with the smaller dimensions assigned to their outer parts.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
I tried to do that, but it gives me not what i want, i need that bottom line would be straight.
Artur.Kosakowski
Move the 'middle' node up a bit Smiley Happy
On the other hand mind that bar element is just the dimensionless object with some properties assigned so that how it looks like when you display the section shape is IMHO the 'secondary' concern. The most important is how you would like this beam to behave (what sort of internal forces you want to see; in other words does this shape cause additional axial force generation or not).
Artur Kosakowski
