Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
eunjucha
1269 Views, 1 Reply
Thermal Load
I would like to know the formula of thermal load for steel you have on load definition based on BS5950 and BS8110.
i try to put the temperature difference of dT 10C in TZ direction and run annalysis.
i expect the emperature induced loads accounted for 10% to 20% of the total axial load though, it does account less than 1 to 2 % of the total axial load in the results.
i have the formula of it , Pt, which is following
Pt = 1.2xk x A x E x (12x10-6) x TD
1.2 = load factor
k = Thermal expansion factor = 0.8
A = Gross area of section of steel
E =Modulus of Elasticity of steel =  205 kN/mm2
TD = temp difference (C)
please help me up to solve that problem.
thanks and regards,
EunJu
1 REPLY 1
Artur.Kosakowski
in reply to: eunjucha
You should define TX instead. TZ (or TY) being the difference of temperature between top and bottom (left and right) fibers cause bending rather than tension/compression. See http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-E4AB6038-D264-45C9-80F9-B06BC687794-448.htm
Artur Kosakowski
