The load has not been distributed correctly
4 REPLIES 4
marko.glavinic89
558 Views, 4 Replies
I get the following message when trying to run calculations for my model.
"The load has not been distributed correctly..."
I have two models. The first model was correct, and calculations ran fine, but after alterating some panels, it all went wrong. I get the warning only for new panels, the ones from the old model are calculated correctly I guess.
4 REPLIES 4
Attach the file with the warning.
Artur Kosakowski
Here.
You have defined loads with no values - delete or correct them.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
yes, this was the problem. thank you !
