Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Tension Only Springs
1 REPLY 1
643 Views, 1 Reply
I am trying to model a baseplate with anchor bolts. How can I model the anchor bolts to act only in tension? For compression forces, the loads should be transferred to the base plate.
1 REPLY 1
Artur.Kosakowski
You can use e.g. unidirectional support or a tension only bar.
Artur Kosakowski
