Till 2009, Robot offered the possibility to define, for footing calculations, soil parameters for a group of footings, it was usefull when the building is big with a lot of footings.
But since 2010 this possibility was no longer available for RSA, now you need to struggle putting for every single footing the soil parameters and thus the type of footing (we are in seismic area and need to use trapeze footing).
My questions are:
- Is there any possibility to define soil parameters for all the footings for a building, naturally they all have the same soil (exept some very rare cases)!
- is the any possibility to define for all the footings the type of footing to use befor launching the calculations, now we have to do it for every single footing and it's time consuming and very boring!
Many thank for your support!
Solved by Artur.Kosakowski. Go to Solution.
My questions are:
At this moment all I can say is that this is not possible in the current version of Robot
I have added this request to the wish list for the next versions of Robot.
Robot 2015
Dear Artur,
That's exactly what we need, many thanks.
Waiting for the other part of the issue related to create directly trapezoidal footing in the feometry screen, or chose the type in the same manner than soil type or other specifications...
Kind regards,
Tarik.
