When modelling walls for a water tank using Eurocode, am I correct in setting the element type to "panel" instead of "wall" in order not to generate boundary elements in the wall?
Solved by Artur.Kosakowski. Go to Solution.
I assume that you refer to the reinforcement distribution generated by the RC design module of Robot. If yes, either this or delete the 'unwanted' reinforcement (I assume that there is no or very small in plane bending in the wall you design).
