Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Tank wall design
1 REPLY 1
stroxy
721 Views, 1 Reply
Tank wall design
When modelling walls for a water tank using Eurocode, am I correct in setting the element type to "panel" instead of "wall" in order not to generate boundary elements in the wall?
1 REPLY 1
Artur.Kosakowski
in reply to: stroxy
I assume that you refer to the reinforcement distribution generated by the RC design module of Robot. If  yes, either this or delete the 'unwanted' reinforcement (I assume that there is no or very small in plane bending in the wall you design).
Artur Kosakowski
