Hi all
From the steel design table, is there any posibility to save the results as .cvs ?
1 How to specify a folder to save the results from ARSA?
You will find in the second file, the diference between the buttons in the shorter list it is no more available the button "Change"
Thanks a lot in advance
Solved by Artur.Kosakowski. Go to Solution.
1. Change is for the selected 'line' only.
2. This is a label rather than a path Intended for the printout composition.
3. Save in Word and then copy via clipboard to Excel
