Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Structure verification through API
3 REPLIES 3
368 Views, 3 Replies
I'm writing a script that removes unitilised bars and i need to check for instability after removal of each bar.
Is there any method in the API that checks the model for singularities without running a full calculation?
3 REPLIES 3
Rafal.Gaweda
No, you have to run calculation.
Rafal Gaweda
in reply to: Rafal.Gaweda
OK.
Is there anyway I can abort the calculations when presented with a warning? I realise that i can abot manually by clicking the dialog box that appers with the warning, but I'm looking for a way to automise this task.
Hope you can help.
Rafal.Gaweda
Very simple example written in C# which shows how to handle the warnings generated by calculation engine and how to break the calculations if needed.
namespace MyCalc
    class Program
        static void Main(string[] args) {
            RobotOM.RobotApplication app = new RobotOM.RobotApplication();
            app.Project.Open(@"c:\Temp\Pdelta.rtd");
            app.Project.CalcEngine.CalcNotifyEx += new RobotOM._IRobotCalcEngineEvents_CalcNotifyExEventHandler(CalcEngine_CalcNotifyEx);
            Console.WriteLine(app.Project.CalcEngine.Calculate().ToString());
            app.Project.CalcEngine.CalcNotifyEx -= new RobotOM._IRobotCalcEngineEvents_CalcNotifyExEventHandler(CalcEngine_CalcNotifyEx);
        static void CalcEngine_CalcNotifyEx(int nCaller, string strText, string strFullText, string strCaption, int nType, int nDataType, string strSelection, out bool bHandled, out int nReturnValue) {
            bHandled = false;
            nReturnValue = 0;
            if (nCaller == 1) { // CALCULATIONS==1
                if (!string.IsNullOrEmpty(strText)) {
                    bHandled = true;
                    nReturnValue = 7; // IDNO=7, break calculations
                    Console.WriteLine(strText);
Rafal Gaweda
Tags (1)
