Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
1003 Views, 4 Replies
Strip footing
I have modelled a metal structure in robot and i want to make strip footing to it. I try some things, like to choose the nodes of the soil in the structure and go to "provided reinforcement of RC element elements", but with this way i create individual footing. Is there any way to make strip footing in the structure?
Thanks, in advance.
4 REPLIES 4
HoshangMustafa
Hi
I Think Artur suggested the attached procedure.
  1. Create a linear support definition  with calculated KZ value
  1. Save soil profile
  1. Define linear support under a wall
  1. Select nodes where you defined supports
  1. Use: Design > Provided Reinforcement of RC Element
  1. Open soil profile
  1. Calculate required size and reinforcement
Mind that for this workflow Robot calculates required area of reinforcement perpendicular to the wall. As it is assumed that the wall is rigid enough to prevent and in in-plane deformation (rigid body behavior) the longitudinal one is assumed as declared by a user.
in reply to: HoshangMustafa
   Yes , but what happens if you don;t have a wall but single steel  columns...
Is this methology right ?
Refaat
Artur.Kosakowski
You may want to watch the recordings of the 4th and 5th RSA webinars:
http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
Artur Kosakowski
