Is is possible to stretch multiple panels, the only way I have found it to do individually via selecting the panel then right click 'object properties' 'polyline - contour - geometry'
Thanks.
Solved by Artur.Kosakowski. Go to Solution.
At the same time ,I don´t know.MAybe with some addin.
But you can stretch a panel without inputting numbers. Just select a panel edge by clicking on it and then click it again ,and then you can drag this edge to wherever you want.
Rafael Medeiros
I have a problem to understand the solution. How does the program know which sides of the selected panels to be stretched to the specified line (coordinates 0,0,7 and 12,0,7) since the whole panels were selected rather than the side of the panels?
If the destination has been defined (the line 0,0,7 and 12,0,7) why is the "Precision" of 2.2m still needed?
Another way (example of drag and drop )
(slide 19 of Webinar 6 ; recording will be available soon)
The program looks for these being closer than the specified precision and this is why it is needed.
