Stress Skin Design
5 REPLIES 5
skilak
2719 Views, 5 Replies
Stress Skin Design
Hi there,
I am designing currently en enclosure (a box) implementing the Stress Skin Design. I have steel beams on the the roof supported by columns - top flanges all at the same level and 8mm aluminium plates bolted to it along every panel (panels are formed by roof beams) perimeter. Is there any method or option of how to offset the shell ?, it seems I cannot find it. I know I can offset the bars but offsetting the shell/panel would be much easier. Thank you in advance for your kind help.
Best regards,
Tomasz
5 REPLIES 5
tony.ridley
in reply to: skilak
not possible. you could use compatible nodes or rigid links perhaps.
skilak
in reply to: tony.ridley
I though aboutt rigid links but if you mesh a panel then, for example, you will have 300 nodes for rigid links;) I am playing now with steelwork offsets to get expected results.
Please, could you explain "compatible nodes" ?
Cheers
Rafal.Gaweda
in reply to: skilak
Use rigid links.
Compatible nodes : check help
Rafal Gaweda
Artur.Kosakowski
in reply to: skilak
If you mesh panels in the same way in some situations it may be easier than you think it is Smiley Wink
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
skilak
in reply to: Artur.Kosakowski
That one is brilliant;) cheers
